OSSC PRO Fan and dinamic resolution
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC PRO Fan and dinamic resolution
  • #66048
    Raiderrr
      Hello, good morning,
      I recently purchased OSSC PRO and installed a 5V Noctua fan as recommended.
      My question is that when the OSSC PRO is off with the LED on red, the fan continues to run. The only way to turn it off completely is to unplug it. Is there an option to disable it when the OSSC PRO is not in use?
      I also wanted to ask, I have framelock enabled at 60Hz, and all games run great, even those with dynamic resolutions. However, there is one where the OSSC PRO goes crazy, which is Killer Instinct Gold for the N64.
      Is this because the game is constantly changing resolution? Thanks for the help.
      #66052
      Ray T
        The fan in mine is stationary when the OSSC PRO is on standby
        #66054
          The fan has to support PWM (4-pin header) in order for the speed control to work.
          Regarding framelock, I suppose you meant you have it at “Off (60Hz)”? If you still get interruptions, try forcing scaler aspect ratio to 4:3.
