OSSC Pro : Max audio samplerate @1080p?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro : Max audio samplerate @1080p?
Viewing 1 post (of 1 total)
  • #60874
    Hojo_Norem
      I’ve been experimenting with my new OSSC Pro and I have discovered that I can only set the audio sample rate above 48KHz if I drop down to 1080i output.  If I try to do 96KHz @ 1080p then my AVR drops the audio link.
      If I connect the OSSC to my PC monitor, it does work at all frequencies @ 1080p but the volume reduces as the sample rate  goes up.  That just might be my monitor though.
      I’ll understand if it’s my AVR at fault.
