I have a question regarding the output when using gbihf-ossc in OSSC Pro’s Pure Line Multiplier mode.
I’m using a GCVideo-DVI adapter to connect the HDMI signal from my GameCube to the HDMI input of the OSSC Pro.
The output of gbihf-ossc is 960×360.
When I set OSSC Pro to Pure Line Multiplier mode and select Line2x 240×360 or Line3x 240×360 under the 384p/400p proc, the output becomes incorrect.
Using Line2x 240×360 results in an output of 1920×1440. The status screen shows x4.
Using Line3x 240×360 results in an output of 2560×1080. However, this signal is treated as 2560×575 by the capture card and monitor. The status screen shows x5.
I tried setting the Pixel Decimation to 4 and changing the input to 240×360, but the result was the same.
If the OSSC Pro’s Pure Line Multiplier behaves the same as the OSSC Classic, I would expect the output to be 720p or 1080p, but that’s not the case.
