OSSC Pro – S-Video add-on – how to get sound
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro – S-Video add-on – how to get sound
  • #65603
    Strike_br
      Dear all,
      This is my first post. I recently bought my OSSC Pro to replace my dying CRT, and to my surprise (I didn’t do my research properly), it won’t work with my stock N64.
      To fix that, I spent more money on the S-video add-on (this time after ensuring it would be possible to use different sound sources with different video inputs).
      The point is, I am struggling. I struggled with the OSSC configuration initially, but I am now discouraged that the sound will not work with the EXT input.
      Is there any solution, or have I wasted money? I would like to keep my games as stock as possible.
      Sorry if this subject has already been addressed. My lack of knowledge about the OSSC Pro limits my search for a proper answer.
      Thanks.
      Strike
      #65604
        You’re connecting the audio to the AV2 RCA inputs on the OSSC Pro, correct?
        #65606
        Strike_br
          Hi Bucko..
          Thanks for answering.  I’m actually connecting to the correct ports. In fact it was a cable problem that I just figured out now. I swapped them and now it’s working fine.
          Thanks again.
          By the way. Since I’m here. Where can I find the best settings for the n64? In a dummie/stupid user kind of guide?
          #65739
            No special settings should be required for N64 unless you wish to dial in optimal timings (https://junkerhq.net/xrgb/index.php?title=Optimal_timings)
