OSSC problem black empty output from C64 svideo signal via Sony S-RGB transcoder
- This topic has 17 replies, 5 voices, and was last updated September 2, 2016 at 7:56 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC problem black empty output from C64 svideo signal via Sony S-RGB transcoder
Ok, mystery solved. Problem definitely was/is the Sony S-RGB transcoder. Basicly the svideo signal had too big voltage level for the Sony to handle, so it got all confused and lost the sync on all-white scenes.
I fixed it by adding some extra resistor on the luminance (Y) signal of the svideo cable to drop the voltage level. After that all-white scenes started working perfectly fine and the Sony transcoder doesn’t mess up the signal anymore!
Nice, can I ask which kind of resistor?
Sure. It was 75 ohm resistor, but that was chosen totally randomly, meaning it was the smallest one I had available. I’m going to try different values in the coming weeks when I get my order from the electronics shop delivered, so I have different resistors to try.
So 75 ohms was enough to fix the problem. I think smaller is probably enough.. I’ll find out.
