OSSC Remotes
- This topic has 3 replies, 3 voices, and was last updated November 18, 2016 at 7:54 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Remotes
Hey OSSC People,
Instead of having to go with yet another remote, Is there a universal code that I can try . I have a scientific atlanta cable box , What manufacturer should I try as a remote code?
NEC generally, if it’s available.
Have a look here – http://junkerhq.net/xrgb/index.php/OSSC#Remote_control_setup There’s documentation for setting up a number of programmable remotes and prontoHEX codes for remotes compatible with that.
the Toshiba codes work rather well with the device. awesome work.
Yea agreed toshiba codes work awesome, I have a harmony 510 remote and could not get the NEC codes to work completely. Then I decided to give a shot to use my toshiba tv that I already had programmed in there and it worked perfect! Now all I have left is to find a working micro SD card that works for firmware update :).
