OSSC + Samsung TV displays grey test pattern, but no console output
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC + Samsung TV displays grey test pattern, but no console output
  • #58042
    sinusamoris
      So, when I hooked up the OSSC with my Wii and PS2 (PAL) to my monitor everything worked without any issues. I then tried to hook it up to my TV (Samsung UE40ES6100)  where I plan on mainly using it. The grey test pattern shows up. I connected my Wii via component to the OSSC, everything works fine. I then connected my PS2, also with component, and as soon as I switch to yPbPr the TV displays a black screen following the message (translated from german): “Resolution not supported. Please change the resolution of the connected external drive.” I tried switching the output options for each of the resolutions to 2x, 3x, 4x, 5x and putting the OSSC into passthrough mode. Nothing works.
      I’m defeated and I do not know what else to do so I’m hoping someone here has some tips or a solution.
      #58067
      JabuJabu
        Trying to understand: so it’s just your ps2 connected to the samsung tv via OSSC not working?
        #58070
        sinusamoris
          Exactly. The Wii works via OSSC. Just the PS2 is making problems. When I connect my PS2 via component directly to the TV it works fine, so no issues regarding the component cable.
