OSSC screen “on” but not working
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC screen “on” but not working
  • #50015
    Orange
      My OSSC turns on, but the lcd shows nothing. It’s just lit on with nothing written on it. Tried turning it on and off, charger off, wait and connect it back, nothing.
      I have a ps2 connected through component/hdmi, and worked fine until now. Didn’t change the settings, or anything. It used to have some dip (sometimes during games, the screen would give me a no signal, but after a while it would come back). There’s just no signal now.
      #50085
        If purchased from us please e-mail in so I can check warranty status.
        #50088
        Orange
          Yes, purchased here on April 17, 2021. What do you need in the email, and at which address?
          #50107
            You can reply directly to the order e-mail or use the contact form here – https://videogameperfection.com/contact-us/ be sure to let me know your order number.
            #50108
            Orange
              Replied to the order e-mail, sending also a new one, in case it doesn’t show up.
