OSSC signal standardisation
  • #25983
    b0nz0beavis
      Anyone know a cheap and non-signal degrading was to standardise the OSSC signal? My OLED on ly accepts 2x by default and 3x with a tweak that wrecks the AR. So I’m looking for the simplest and most cost effective way to make my display accept the OSSC signal.
      #25992
        I answered this in your thread on shmups:
        Depends on your definition of “cheap”, I suppose. The Extron DSC 301 HD works well–deinterlaces, seems to take any line multiplication method you can throw at it–but you can expect to pay $50~$100 (or more) for one, and you’ll end up with slow resolution transitions (3 sec using the HDMI input, 1 sec using an HDMI to VGA converter and using the analogue input).
        You could also try any of the HDMI-to-HDMI scalers on Amazon or eBay, but those all seem to fall into the same price range.
        Either way, you’ll be spending less than if you bought a new 4K display.
        #26001
        b0nz0beavis
          Thanks for the reply. I’ve updated the shmups thread as twere were various other replies there also.
          For any users not also on shmups, happy to read your input here.
