OSSC v1.8 freezing and behaving strangely
- This topic has 0 replies, 1 voice, and was last updated January 9, 2026 at 6:58 PM by .
Viewing 1 post (of 1 total)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – DIY & Repair Support › OSSC v1.8 freezing and behaving strangely
I’ve bought an OSSC v1.8 from VGP about two years ago. I think it had firmware v1.07 or v1.08 installed before I’ve upgraded to v1.20 a few days ago. The update succeeded and then I have used the device for that evening.
On the next day, the OSSC failed to start up properly. The OSSC showed its startup message displaying the firmware version (1.20), but didn’t react to any input. HDMI output was generated, showing the test image, but otherwise the device seemed dead. I tried various things, power cycled a few times, then suddenly I was able to change inputs using button 0, only the input names were messed up (garbled strings). The same garbled strings were visible on the TV. Opening the menu didn’t work because the OSSC still didn’t react to the remote control.
Unable to change the firmware from the menu, I grabbed my USB Blaster, installed Quartus Prime Lite, and followed the instructions for installing firmware via JTAG. Since there is no .jic file for v1.20 on the GitHub release page, I’ve used the ossc_1.01-aud.jic file as found at http://www.infocult.com/m/ossc/fw/v1-series/ (linked from https://junkerhq.net/xrgb/index.php) for the purpose of upgrading to 1.20 again.
Quartus detected the device, flashed the firmware, but the CRC verification step failed. Anyway, the OSSC display showed 1.01a, the remote control worked again, and I was able to open the menu, so I played around a bit. Then, the OSSC started freezing and behaved similar to before with firmware 1.20. JTAG revived the device again, again with CRC error, and it stopped working again after a few minutes of use. I’ve flashed several times, tried other .jic files, but the CRC verification step failed each time.
Given that I see these CRC errors, I guess that the SPI flash memory chip (U10, labeled IS25LP016 DNLE) might be broken. Is there a way to confirm this? Or could there be something else which may cause the problems I have? I want to be reasonably sure about this, as the IC is rather difficult to find and also quite expensive.
Thank you!
