It’s not possible, since A1 OUT is hardwired directly to the SCART connector. So there’s nothing to do about it on the software side. A new hardware revision would be needed.
But why not use a separate y-cable or a cable/input switch on the pc speakers?
I am using a manual switcher now. I just thought it was more elegant going to the OSSC. Oh well, can’t have it all 🙂
I appreciate the answer to my question though!
Hi!
I have problem with 1.10 and 1.11 firmware versions. On 1.09 firmware everything shows correct in default settings on x5 mode. On versions 1.10 and 1.11 I get green pixels and lines in dark areas. Nothing else is changed than firmware, both pictures have default settings just mode changed to x5. On lower x modes everything works. I have SNES with 60Hz and Dejitter mods, and I use PACKAPUNCH RGB scart cable
