OSSC with Amiga 1200 – Can flickering be reduced?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC with Amiga 1200 – Can flickering be reduced?
  • #35131
    mateusz_s
      Can flickering be reduced when Amiga 1200 is using 640×512 interlaced mode?
      I can’t chceck the advanced options myself because I don’t have a remote yet.
      At basic options the image is flickering. I was a bit dissapointed because a lot cheaper SCART to HDMI had reduced flickering.
      #35134
        If your display has a deinterlacer, you can switch to passthrough mode for interlace sources then use line multiplication for games.
