OSSC With AV Receiver Onkyo
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC With AV Receiver Onkyo
- This topic has 10 replies, 4 voices, and was last updated November 19, 2016 at 10:36 AM by
BuckoA51.
November 17, 2016 at 1:02 AM #9636
Hey ,
I was one of the Lucky few to get one of these .I finally got a DVI-HDMI cable and began the test (I don’t have a remote )
I want to run this thru my receiver ONKYO-NR-515 it has 7 HDMI inputs and one out but when ever I use it I get a blue screen . some how it doesnt detect the signal.If I use it directly with my TV It works but it uses my only working HDMI port
I have tried a regular HDMI switch but that made the video and audio streams cut out sporadically (making any TV related fun completely suck)
And No I do not wish to buy a new TV because the audio in TV keep getting shittier.
Is there a setting that tweaks the DVI output or can some one point me in the right direction?
I know that the receiver won’t accept any outputs lower that 480i (no 240P games or systemsThe most retro system that works with it is an Xbox
Thanks
November 17, 2016 at 1:16 AM #9638Just to update you all:
Without selecting AV1-3 I can see the test pattern.
Running the “display” command I see that the test pattern is HDMI IN RGB 24Bit 720×480.
The Input source on the Xbox is set to AV2 (Component cables )
the ossc shows 525i , 15. 73Khz 59.94hz
I assume i need 480P / I out not the 525 PAL ?
November 17, 2016 at 5:05 AM #9641I have almost exactly the same problem with my Yamaha RX379. I’m able to only get an intermittent image from the Dreamcast in VGA mode. 480i content is so far a non starter and subsequently so is 240p. What confuses me though is that I thought 480i content was line doubled to a progressive output, so why would the Dreamcast work with a 480p output but not the line doubled output of 480i content from a PS2? I wonder if a line x2 mode for 480/576i content would solve the problem. My TV does seem to accept the 480px2 mode when connected directly.
Linex3 mode for 240p content might work for you; definitely worth a shot if you haven’t tried so already.
November 17, 2016 at 2:49 PM #9658480i content is line-doubled to 480p unless you have interlace pass-through turned on.
Do either of those receivers include any picture processing features?
November 18, 2016 at 12:56 AM #9675The TX-NR515 does support up scaling to even 4K.
from my understanding the OSSC isnt a frame buffer so there could be a few less or more lines that could be affecting the picture.
http://www.intl.onkyo.com/products/av_components/av_receivers/tx-nr515/index.html
November 18, 2016 at 1:36 AM #9677Now that I have a programmed remote I can finally See all the settings. but for the life of me I cant getthe Yprbr input (xbox ) to display. if I set the output to 575i passthru I get a resolution error on the AV receiver and the TV shows “not available ” instead of no signal.
the other picture modes “3x or 2x ” don’t seem to change that number.
I also think that the Tripling / doubling is not takng affect on the test pattern screen.
Is there any way to not have it out as 525i
November 18, 2016 at 2:30 AM #9678Now that I have a programmed remote I can finally See all the settings. but for the life of me I cant getthe Yprbr input (xbox ) to display. if I set the output to 575i passthru I get a resolution error on the AV receiver and the TV shows “not available ” instead of no signal.
UPDATE:
Using my TV (Olevia 747i ) it was telling me the displayed resolution when line doubler was on was 1360×1024 . its a weird resolution that wouldn’ t allow the receiver to work (blue screen signal)
not sure how to enable the tripler, switching it to on didnt do anything .
currently i have it running as 480P with scanlines ^% and then running to the onkyo with output set to 1080p . looks very stunning for the xbox . the rest of the settings are defaults. (Xbox confirmed works )I’m still learning about this device but I found that resolution odd
UPDATE:
It looks like Games work but the main menu does not:
When Game is inserted: 31.46Khz , 525P 59.94Hz
When menu/startup : 15.73Khz , 525i , 59.94HzWhats the cause for this Frequency change and how can we have the OSSC detect this?
November 18, 2016 at 6:14 PM #9700I also think that the Tripling / doubling is not takng affect on the test pattern screen.
Correct it does not.
Linetriple is for 240p/288p sources only.
Your Xbox is changing from interlace to progressive.
I’d suggest bypassing or disabling your AV receivers scaler, usually there’s a disable/bypass setting.
November 19, 2016 at 12:06 AM #9717Yes, I’d set receiver to passthrough mode if possible to avoid extra processing & lag. I don’t understand why menu (525i input) doesn’t work in your setup since output should be pretty much identical to when using 525p input source. If you want to use OSSC interlace passthrough, you may need to switch TX mode to HDMI since some devices do not accept interlaced signals in DVI mode.
November 19, 2016 at 12:48 AM #9723I have enabled passthru or “direct” as the output mode.
its having issues with the 15.73Khz signal (FW 0.73)
Using the 480i passthru in the menu causes a “resolution error”
Is there a way to bump this to 31.73 khz (or super impose this)
I have tried a Xbox 480P games (Burnout revenge) and a 480i games (Starwars/tetris) that worked fine in i /p
The PS2 as thru component is not working in the slightest (Ps2 Slim)
November 19, 2016 at 10:36 AM #9730Is there a way to bump this to 31.73 khz (or super impose this)
Deinterlace it you mean? Yes, by turning passthrough mode off.
