PAL 1Chip SNES with 60Hz switch installed – will the dejitter mod work on it?
NewHome Forums Repairs and Upgrades PAL 1Chip SNES with 60Hz switch installed – will the dejitter mod work on it?
  • #41573
    snk64
      Hi, I’m new here, so I’m sorry for the noobish question.
      I have bought an OSSC recently, and hooked up my SNES to it with an official SNES RGB SCART cable, only to find out that Linex3 and Linex5 modes have issues on 60Hz with the video signal dropping out ocasionally. After researching I found out that jittery sync signal is the culprit so I’d need to install a dejitter mod.
      What I’d like to know is that if my PAL 1Chip SNES that has a 60Hz and a disable region lockout switch installed, will the dejitter mod work on it? The store page on this site says that on PAL consoles I’d have to have the SuperCIC mod installed for it to work, but searching the web I found a couple of posts that mention having installed the dejitter mod without the SuperCIC so I’d like some confirmation on that if it’s possible. Thanks!
      #42109
        Yes it will work, only in 60hz mode though (it’s not required in 50hz mode)
