Pal N64 svideo
Viewing 1 post (of 1 total)
  • #39545
    leewrigley
      I have a pal N64 hooked up through the koryuu through the svideo cable from the website consolegoods, which is the only svideo cable I could find that displays correctly on a pal console.
      The problem is that when scaled through the Ossc this cable produces nasty interference which is super distracting.
      I wanted to know that if I bought a high quality svideo cable is there any Ossc settings which could correct the blown out colour from a normal svideo cable on the n64,?
      Thanks
