PAL Profiles for Framemeister
NewHome Forums General gaming PAL Profiles for Framemeister
  • #35298
    Opaque79
      I decided to share my profiles for the Framemeister made with PAL consoles. I would appreciate if anyone can test these on their setups if possible. They are 4x scale of PAL content made with FBX’s profiles as a base.
      Here they are
      FM PAL Profiles 4x
      Hope they are good enough.
      I’ve removed the Dreamcast progressive profile as it is just FBX’s profile. The DCINT profile is intended for DC games running in 576i@50Hz
      It is also thanks to FBX for giving as much support as possible when making these.
      #35320
        Interesting, this should really be added to the Wiki if people find them useful.
        #35327
        Opaque79
          I really hope so. Would appreciate feedback.
          #35482
          Opaque79
            If you think these should be added to whatever Wiki you are referring to, feel free to add them.
            #36234
            Scott
              Thanks, been looking for some PAL profiles!
              Which systems are the DCINT.Bin, Drive.bin, Driver256.bin and Default.bin profiles for exactly?
              #36454
              Opaque79
                DCINT = Dreamcast Interlaced
                DRIVE = Mega Drive
                DRIVE256 = Mega Drive 256 res mode
                DEFAULT = Framemeister Default Settings with 1080p resolution
                For 480p consoles, best check out FireBrandx’s profiles. Mine are for 288p and 576i only (PAL resolutions)
                Are they working OK for you?
                #39016
                Jarrah White
                  Do you have any PAL profiles for Sega Saturn, original Xbox, and GameCube? Also, I could not test your NES profile because mine is not RGB-modified. Do you have a composite video PAL profile for NES?
                  #39020
                  Opaque79
                    I don’t have those particular systems and I don’t have a standard NES. I did have a Gamecube 50Hz profile but I seem to have lost that one.
                    For Gamecube, I force 480p using Nintendont. I use the OSSC so I don’t need FM proflies.
                    From memory, you can set ZOOM_SIZE to 94 and ZOOM_WIDTH to 43 for 50Hz Gamecube games to get the correct scale.
                    #42338
                    Scott
                      Finally got around to trying them. Beautiful – they all work great!. Thanks.
                      P.S. Do you have any for home computer systems such as Amstrad, C64, Amiga, Atari ST? I’m also look for a good Colecovision profile.
                      #42339
                      Opaque79
                        Good to hear
                        I do not have those systems so I don’t have profiles for them
                        #48473
                        Jarrah White
                          Sorry to dig up this old thread, but these profiles all assume RGB is used. On my Dreamcast I use the official VGA adapter with S-video and composite for interlaced mode. Do you have any corresponding PAL profiles for composite and S-video
                          #48479
                          Opaque79
                            You should be able to load the profiles and select the input you want. I do not have profiles for composite and S-Video as I don’t use them
                            #48480
                            Jarrah White
                              That’s news to me, whenever I select a profile on mine the settings of that profile do not carry over to a different input. Is there a setting for that which I don’t know about?
                              #48482
                              Opaque79
                                Don’t really know. Haven’t used the Framemeister for a long time after switching to the OSSC
