Pass through looks better then X4 at 480i?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Pass through looks better then X4 at 480i?
  • #17734
    JoeTheUseless
      Hi there i have my GameCube connected with a generic RGB scart cable with the OSSC. Pass through looks fine X2 darkens the image x3 doesn’t work for me just sound. And X4 is really dark how do i improve the 480i picture quality and make x4 brighter i am using a 42inch LG HDTV with GAME mode enabled ๐Ÿ™‚
      Can incompatible TV’s give out an inferior picture when scaled up?. I will try another TV later i can’t remember how this RGB scart cable is wired i bought it a few years ago on Ebay ๐Ÿ˜ฎ
      Update i have connected the OSSC to my 27inch Acer PC monitor and it looks incredible i just wished it looked as nice on my HDTV. i might have to make a setup using this Monitor i will keep troubleshooting ๐Ÿ™‚
      Any ideas in the meantime? ๐Ÿ™‚
      Thanks
      #17763
        interlace generally does look worse on anything other than passthrough. The deinterlacer in the OSSC is designed to remove input lag not improve picture quality. Good quality deinterlacing requires a frame buffer (and a trade off in input lag).
        You can’t have nice deinterlacing with no input lag, you have to make the trade off one way or another.
