Philips CDi 470 RGB mod
NewHome Forums Repairs and Upgrades Philips CDi 470 RGB mod
Viewing 15 posts - 1 through 15 (of 33 total)
  • #57036
    AlexS
      We installed the RGB board in a Philips CDi 470, however composite/YC doesn’t turn off and RGB mode isn’t activated. It should be done with pin 14 but it doesn’t work. Any ideas? Thanks for your help
      • This topic was modified 2 years, 5 months ago by BuckoA51.
      #57039
        I asked Chris from Mobius Strip Tech, he asked “did you remove resistor 3171 from the bottom of the CDi main board” ?
        #57088
        AlexS
          Thanks, we did this one as well, according to the manual. We really don’t know anymore what to do
          #57092
            Can you post up some pictures of your install?
            #57094
            AlexS
              #57095
              AlexS
                #57096
                AlexS
                  AlexS
                    AlexS
                      <p style=”text-align: left;”></p>
                      #57099
                      AlexS
                        AlexS
                          AlexS
                            #57102
                            AlexS
                              AlexS
                                thank you for your help. If you need more pics just tell me
                                #57109
                                  I sent your pictures over to Chris at Mobius he said the following:-
                                  They didn’t bridge the jumpers for RGB on the RGB board. It’s not in my instructions but it’s on the GitHub page, because when I was selling the boards, the jumpers didn’t exist
                                  https://github.com/mobiusstriptech/CD-i-RGB
                                  They also don’t need to solder the RGB enable pad because they moved the resistor on the mainboard
                                  • This reply was modified 2 years, 4 months ago by BuckoA51.
