Philips CDi 470 RGB mod
NewHome Forums Repairs and Upgrades Philips CDi 470 RGB mod
Viewing 15 posts - 16 through 30 (of 33 total)
  • #57113
    AlexS
      Thank you very much for your help, I hope this will do the trick
      #57133
      AlexS
        I’m sorry I have to ask again, but just to be sure: are you referring to this part on your github-page:”Built-in RGB Enable pad. No more soldering in a pull-up resistor.”?
        #57134
        AlexS
          Of course I mean this part, please forget the upper posting:”470 (Tested Working. Requires Solder Jumper to Left.)”
          #57135
          AlexS
            <p style=”text-align: left;”>Of course I mean this part, please forget the upper posting:”470 (Tested Working. Requires Solder Jumper to Left.)”</p>
            #57136
            AlexS
              Also about your second hint:”They also don’t need to solder the RGB enable pad because they moved the resistor on the mainboard” does this mean we don’t have to do part 4 of your instructions, because we did part 5, removing the 3171 resistor? Sorry that we need to ask so often, but this seems to be trickier than expected. Thank you for your help
              #57169
              AlexS
                Current status
                #57170
                AlexS
                  Back again, still not done. Our assumption is that we have to remove the resistor from pin 13, this might activate RGB. Anyone can confirm this?
                  #57171
                  AlexS
                    About the last pic I posted: here the resistor is set on 3161 which should activate RGB. 3170 is composite video, this  resistor is on the back side on mass flow/minus but it could also be done on the front side on Plus. Any idea which one is the correct one? Thank you!
                    #57215
                      I’ll see if I can get Chris’ attention again!
                      #57216
                        “You should remove any wire you may have soldered to pin 13, but leave the resistor you soldered at 3161.
                        Then make sure that you solder the jumpers to the left for RGB signals”
                        • This reply was modified 2 years, 3 months ago by BuckoA51.
                        #57256
                        AlexS
                          Thank you for your help, it’s working! Mostly. All jumpers are left now, but is it normal that conposite is still working? Also, the image is too bright, see the pics below. Any final clues to solve this would be very welcome. Thank you!
                          • This reply was modified 2 years, 3 months ago by AlexS.
                          #57257
                          AlexS
                            AlexS
                              Rgb too light
                              #57259
                              AlexS
                                Composite
                                #57260
                                AlexS
