Pinout for OSSC AV3 Dsub 15 / VGA input?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Pinout for OSSC AV3 Dsub 15 / VGA input?
- This topic has 8 replies, 5 voices, and was last updated February 19, 2021 at 5:52 PM by
Dazzer10.
March 19, 2018 at 11:45 PM #20222
I’ve been looking for the pinout OSSC uses for the Dsub 15. I mean, I get that it uses the same pinout as VGA for VGA sources, but what about RGB? YPbPr? Audio?
Google has failed me. I’m not seeing it in the online manual. The Wiki linked to in the stickied threads above just dead-end in the page about the AV3 input.
I recall hearing somewhere (RetroRGB podcast?) that it was made to use a set of cheap cables from Monoprice but I’m not even finding pinouts there.
I have an OSSC1.5 with the audio upgrade board so I know mine isn’t wired for audio through the 15 pin Dsub, but are the newer ones?
What I’m trying to do is use the three inputs in a way that avoids buying a switch. Actually, I already have switches but I’d still prefer not using them. I’m sticking primarily with SNES and Genesis/Megadrive HD Retrovision cables so that I can adapt two sets of quality cables to various consoles rather than have a ton of quality shielded cables made for each console. This sidesteps a lot of the indiosyncracies of each platform (no worrying about sync type/cleanliness, resistors, capacitors, cable vs. internal, etc). Luckily, the HD Retrovision cables were engineered to be used together with a few Y-cables, so they can share AV2 and connect NES RGB modded AV Famicom, SNES, N64, GameCube (with mods), Master System, Genesis 1/Sega CD, Genesis 2/32X, Saturn, Neo Geo, and TurboGrafx-16 (with Super SD System 3), and more. I can kill a lot of birds with two stones.
AV1 is often used for audio input but I’d also like to wire audio to AV3 if 1.6+ supports this. A local thrift store has some unused and heavily shielded Dsub15 to RCA cinch YPbPr cables that I will happily buy if they look like the right pinout (I’ll bring my meter to the store).
TL;DR:
I need the full OSSC AV3 VGA input pinout (not just VGA). Thanks!March 20, 2018 at 5:08 PM #20239I’ve been looking for the pinout OSSC uses for the Dsub 15. I mean, I get that it uses the same pinout as VGA for VGA sources, but what about RGB? YPbPr? Audio?
VGA is RGB; RGBHV, specifically. For RGBS, same as RGBHV, but composite sync goes on the horizontal sync line. RGsB is the same as well, but with no dedicated sync line. For YPbPr, sames as RGsB, matched to cable color: Y to G, Pb to B, Pr to R.
You do need to keep in mind that AV3 has limited low pass filter capabilities, and that the wiki recommends connecting older consoles (which I believe means all of the consoles you mentioned) to the other inputs.
No; VGA cables do not carry audio. The OSSC 1.6 has a 3.5mm TRS jack for audio input for AV3, located next to the DE-15 port.
I don’t have one, but I believe the OSSC 1.5 with the expansion audio board can only accept one audio input at a time, either via SCART on AV1 or via the 3.5mm jack next to the DVI port; meaning all of your video inputs will have to share this one audio input.
You can also kill either the OSSC or your consoles if you turn two of them on at the same time (accidentally or otherwise) when they’re connected with simple Y-cables, as this may cause voltage to spike on the video and/or audio lines and exceed specification. (Just because HD Retrovision says you can do it doesn’t mean you should.)
I know you don’t want to use a switch, but, if you need to have two cables share AV2, I would not recommend anything less; use an automatic switch if you want it to be hands-off.
March 22, 2018 at 1:01 AM #20301I’ve been looking for the pinout OSSC uses for the Dsub 15. I mean, I get that it uses the same pinout as VGA for VGA sources, but what about RGB? YPbPr? Audio?
Yes, of course, but in context I was talking about non-VGA RGB (no discrete H/V sync; 31khz and below) so as to avoid listing all the different types. So, OSSC will tolerate/accept TTL sync, composite sync, and sync on composite video all through the same pin (VGA horizontal sync)? Good to know. Thanks!
Yes, I’m aware. All the consoles I listed were for the AV2 input with two HD Retrovision cables and a suite of adapters, though I may want to move GameCube to AV3 specifically to avoid the LPF (PlayStation 2/3 as well). I’m unsure which video mod I’m ultimately going to implement after selling my original component cables months ago but I don’t think an LPF would be ideal regardless. Heck, I might do HDMI-only there. AV3 would be primarily for things like DVD/BD players or for testing to see if an LPF is desirable for a particular device.
I don’t have one, but I believe the OSSC 1.5 with the expansion audio board can only accept one audio input at a time, either via SCART on AV1 or via the 3.5mm jack next to the DVI port; meaning all of your video inputs will have to share this one audio input.Thanks. I realize now that what I read about a VGA port being used to carry other signals and being designed around the pinout for a set of cheap Monoprice cables was in relation to the Analogue Nt and Nt Mini. I was wrongheadedly asking for the Nt Mini’s Dsub 15 pinout all along. I sold the Nt Mini when prices got crazy earlier this year so, no, I won’t be looking to connect audio to the expansion board through unused VGA pins just for the Nt Mini. 😉
With that setup it wouldn’t even be possible to power most while connected simultaneously since all non-Nintendo consoles would have to go through the Genesis cables with the appropriate adapter and the cables can’t physically connect to more than one simultaneously. The feature is specifically billed as an alternative to switchboxes and multiple cables (http://www.hdretrovision.com/vote3rdparty/) so I would hope they have engineered some way to prevent damage. If not, well, you warned me and I have only myself to blame. “Hands off” was never really a goal of mine but getting maximum utility out of two quality cables versus buying 10+ well built shielded cables and a gSCART switch was. 🙂 I have multiple component switch boxes (two are even marketed for game consoles) but the extra complexity only makes sense for more long-term setups than I intend to have (most will get disconnected as soon as I’m done playing).
Thanks for your help!
March 22, 2018 at 1:09 AM #20304So, OSSC will tolerate/accept TTL sync, composite sync, and sync on composite video all through the same pin (VGA horizontal sync)?
No, not quite. AV1 can accept composite sync, luma, or composite video as sync, but must be 75Ohm-terminated–sending AV1 TTL sync will likely blow something.
AV3 requires TTL CSync or HV sync–it will not accept composite or luma, nor 75Ohm-terminated signaling.
March 22, 2018 at 1:18 AM #20305AV1 can accept composite sync, luma, or composite video as sync, but must be 75Ohm-terminated–sending AV1 TTL sync will likely blow something.
…and yet it will accept standard YPbPr and RGsB without TTL sync? I’ll make a note of that. Thanks again. Luckily, I still have AV1 generally unused for anything I encounter that happens to need RGBS, sync on luma, or composite video sync.
March 22, 2018 at 3:14 AM #20310…and yet it will accept standard YPbPr and RGsB without TTL sync?
Correct; because sync is muxed on Y and G for YPbPr and RGsB respectively, the TTL/75Ohm issue is irrelevant for those formats.
March 22, 2018 at 10:24 AM #20315You don’t need to avoid AV1 to avoid the LPF it can simply be turned off if necessary.
February 19, 2021 at 5:01 PM #45388Hi…real VGA requires separate H and V TTL sync, so no, it wouldn’t work with genuine VGA. Notwithstanding, some VGA shows can acknowledge csync or match up on-green, which can be gone through SCART. My old Viewsonic CRT did. Nonetheless, sync-on-composite is most likely not going to work.
February 19, 2021 at 5:52 PM #45389** reply to wrong topic ** deleted
