PLEASE HELP ME IM SO CLOSE. (OSSC)
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support PLEASE HELP ME IM SO CLOSE. (OSSC)
  • #61582
    ellervis
      After a PAINFULL attemp, i’m so close to be where i want. I want to record PS2 games with good quality. I bought a kaico 1,7 and have an Elgato hd60s+, i also did order a special memory card so i could upscale my ps2 with GMC 0,38 and it working. Before it was also flickering in all games, BUT there is some strange lines/flicker, and is only when i take 1080 from MCBOOT. I not have the retrovision component cable tho, but not a cheap one either, but is that the reason? This is how it looks like...
      #61603
        I’m not sure where those jailbars are coming from, but it definitely looks like something leaking into the signal.
        Unless you run into compatibility issues with the capture card it’s probably best to use GMC to only force progressive output for supported games and let the OSSC do the rest of the line and pixel doubling.
