Powering up my OSSC I get this picture. Need Help.
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Powering up my OSSC I get this picture. Need Help.
  • #16124
    Kameleo
      First time it did it, I just restarted it, now I don’t know what to do.
      #16142
      soulBit
        The second video shows the grey test pattern that the OSSC outputs when it boots up for the first time, nothing to worry about – not sure what’s up with the flickering at the bottom of the screen though.
        #16145
        Kameleo
          I know about the test pattern. Just wanted to show that it does it even without any signal input. The flickering at the bottom is what bothers me. Restarting it after 30 minutes resolved it, again. It might be my capture card, but it’s not the cables. Just want to be sure it’s not the unit. I’ll do more test if it does it again. If anybody has seen this before, can you help me identify the problem?
          #16146
            Perhaps you have your capture card set to 640×480 VGA when it should be 720×480 480p?
