Problem upgrading firmware: SD not detected
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Problem upgrading firmware: SD not detected
  • #7616
    zeruel85
      Hello!
      I’ve just finished to build an OSSC for a friend of mine. When I boot up, the menu says ‘OSSC fw. 0.67’ and I want to upgrade it. I saw the tutorial by Bucko on YouTube, everything is pretty clear, but my OSSC always returns ‘No SD card det.’ with three different uSDs.
      What could I do? Thanks!
      P.S.: if there is some sort of incompatibility with my uSDs, I also have a USB mini Blaster for upgrading Altera FPGAs via JTAG mode, but honestly I don’t know how to proceed with the OSSC.
      #7621
        It could be an incompatibility, are you using SD or SDHC cards?
        #7625
        zeruel85
          I only have SDHC microSDs, it’s not so common finding old normal nonHC < 2GB.
          #7629
            That’s probably the issue then, OSSC is a bit picky and prefers the old SD cards. This is being worked on for a new firmware… though, that’s a little bit of a catch 22 for you I’m sorry to say.
            #7632
            zeruel85
              I talked with Markus. He’s a very gentleman, he gave me a JIG file to use with the JTAG port. 🙂
              ASAP I’ll test it. Thanks for now.
