Problems with OSSC and PS2
  • #9582
    Kenny8215
      Hey,
      today I got my OSSC. I hooked it up to my PS2 and my TV and turned it on. But the TV screen remained black. It’s a PAL PS2 and I used a PS1 game. The PS2 is connected via a RGB scart cable and the sync LED is not red. As soon as I switched the Lx3 option on, my tv said “picture mode not supported”. After that I tried my Wii with a component cable and that works perfectly. My TV is a Phillips 32PFL6606K/02. And I also tried the same with the PS2 and my Computer Screen, that also does not work.
      I hope someone can help me.
      #9583
        Do you get a picture with the PS2 when no game is inserted and it’s just on the dashboard?
        #9585
        Kenny8215
          No, nothing.
          #9587
          paulb_nl
            Have you tried another console with scart?
            #9588
            Kenny8215
              The only other console I have right now is the PS1 and I think the output of the PS2 with a PS1 game is the same as the PS1. My TV still has a scart port and I get a picture from the PS2 over that port, so its definitely not the fault of the console.
              #9589
              paulb_nl
                Alright. Trying another console was meant for ruling out a problem with your scart cable or with the OSSC. Which RGB scart cable are you using? Some scart cables marked as RGB are not actually wired for RGB.
                #9590
                Kenny8215
                  I’m using the original cable and scart adapter that came with the ps2.
                  #9591
                  paulb_nl
                    Well thats the problem. The original cable with scart adapter is not RGB but composite video only.
                    #9593
                    Kenny8215
                      Well, now I’m feeling stupid 😀 All those years I thought that was a RGB cable. Thanks for the tip.^^
                      #9597
                      paulb_nl
                        Then you have been missing out! 🙂
