Program L336 remote with default codes
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Program L336 remote with default codes
  • #15470
    weux
      I wanted to save a few bucks and program my own L336 remote with the default OSSC codes, so I created this LIRC config to transmit the codes from my computer. Here’s the config for anyone that wants to do the same.
      begin remote
        name  ossc
        bits           32
        flags SPACE_ENC|CONST_LENGTH
        eps            30
        aeps          100
        header       9024  4512
        one           564  1692
        zero          564   564
        ptrail        564
        repeat		9024  2256
        gap          108000
        frequency    38400
            begin codes
                1                        0x3EC129D6
                2                        0x3EC1A956
                3                        0x3EC16996
                4                        0x3EC1E916
                5                        0x3EC119E6
                6                        0x3EC19966
                7                        0x3EC159A6
                8                        0x3EC1D926
                9                        0x3EC139C6
                0                        0x3EC1C936
                10+                      0x3EC1B946
                TOGGLE/RETURN            0x3EC17986
                PIC/CANCEL               0x3EC18D72
                MENU                     0x3EC14DB2
                EXIT                     0x3EC1ED12
                INFO                     0x3EC1659A
                CLOCK/EJECT              0x3EC1D12E
                REWIND                   0x3EC1619E
                FORWARD                  0x3EC1E11E
                L/R                      0x3EC1B54A
                PAUSE/ZOOM               0x3EC1C13E
                CHAPTER-                 0x3EC19D62
                CHAPTER+                 0x3EC15DA2
                STOP                     0x3EC1A15E
                PLAY                     0x3EC141BE
                LEFT                     0x3EC1AD52
                RIGHT                    0x3EC16D92
                UP                       0x3EC12DD2
                DOWN                     0x3EC1CD32
                OK                       0x3EC11DE2
                POWER                    0x3EC101FE
                VOL-                     0x1CE3F00F
                VOL+                     0x1CE3708F
                MUTE                     0x1CE318E7
                CH+                      0x1CE350AF
                CH-                      0x1CE3D02F
                TV/AV                    0x1CE3C837
                PNS                      0x1CE348B7
                TONE-                    0x5EA1D827
                TONE+                    0x5EA158A7
            end codes
      end remote
      #15533
        Can you point us in the direction of the software that you need to do this with?
        #15539
        weux
          You can use LIRC for linux or WinLIRC for Windows. Both use the same format for the remote config.
          As far as hardware, I made one of these with some parts I had laying around.
          #15556
            Thanks, I’ll pop that up on the Wiki when I get a moment.
