PS2 – OSSC or RetroTINK 2x
NewHome Forums RetroTink Products PS2 – OSSC or RetroTINK 2x
  • #26623
    bamf226
      After hooking up my PS2 to the OSSC, the best picture is by passthrough thanks to the 480i. I was considering hooking the PS2 up to the RetroTINK to convert the 480i to 480p and then pass that into the OSSC. Will I get any significant improvement in the picture quality this way or should I just stick with passthrough of the OSSC?
      #26626
        Stick with passthrough; the RT2X uses the same bob deinterlacing that the OSSC uses. Plus, you won’t be able to use 480p/720p/1080i video modes from compatible games.
        #26627
        bamf226
          Will the optimal timings I found on a different web site make any difference with passthrough on the OSSC?
          #26638
          mikechi2
            Pass-thru on the OSSC is probably giving you the best image since it let’s your TV do a real de-interlace (at the expense of lag). Unfortunately, the 2X won’t be of any assistance there. Sorry.
