Question regarding SNES PAL consoles
- This topic has 21 replies, 7 voices, and was last updated September 5, 2017 at 8:32 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Question regarding SNES PAL consoles
It works because it has a sync stripper in the scart head. It takes the composite video signal and filters out the video content. This type of cable exist because some switchers and video monitors only accept csync.
It will work fine on the OSSC also.
You should verify with the seller that your PAL csync cable with sync stripper has a 470 Ohm resistor on the output of the sync stripper. The resistor is missing from the photos on their website. The OSSC is not designed for TTL level sync on the SCART input so the resistor needs to be on there.
Oh, I was assuming since it uses composite video as the source, it would be at the correct level already. Guess not then?
Edit: I see in the scart schematic for PAL snes, it does need a 75 Ohm pull down resistor on the composite video line. So the addition of 470 Ohm resistor implies that there is some amplification due to the LM1881 circuit? Sorry if it’s a stupid question, I’m not that knowledgable in electronics…
Apparently the LM1881 always outputs 5volt TTL sync. Viletim talks about it here: http://shmups.system11.org/viewtopic.php?p=1153713#p1153713
Yes, there are 3 flaws I’ve repeatedly seen in most “sync stripper” cables:
1. Missing 75ohm termination resistor in LM1881 input (before the cap)
2. LM1881 is placed inside the scart assembly at the display end of the cable, even though ideally it should be on the other end
3. Missing 75ohm sync driver (or series resistor) on LM1881 output (OK if the purpose is to generate TTL level sync)
In practice, the end result is often still somewhat working even if all those flaws exist. The effective voltage level from LM1881 drops to much lower level if directly loaded by 75ohm termination inside TV, OSSC etc.
@BonzoBits – how is your TV (UA55D6000SMXXY) running with the latest firmware revisions? Does SNES work on it?
Thanks!
@jonlad I just answered in the TV Compatibility Thread. Not sure yet, will update once I’ve been able to do a test. Won’t be for a while though.
