Random noise in image, tried nearly everything, have no idea how to proceed.
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Random noise in image, tried nearly everything, have no idea how to proceed.
  • #37768
    nrq
      Hello,
      there’s some random noise in my image I can’t get rid of. Weird thing is, I don’t remember it being there in the beginning, I think I just noticed it a month or two ago when I got a new TV. Problem is, it’s not the TV, I can capture the noise just fine, as you can see in this video:
      Title screen
      Link’s house
      It’s especially apparent on the title screen and in Link’s house, but it’s there all the time in all games and in all modes.
      My setup is as follows:
      * PAL 1chip SNES
      Mods:
      – SuperCIC (from Videogameperfection)
      – Dejitter Mod (from Videogameperfection)
      – borti’s RGB bypass
      * PAL “2chip” (?) SNES
      Mods:
      – regular PPU1/2 50/60 Hz switch
      – lockout chip pin4 disabled
      * OSSC (from Videogameperfection)
      – Line5x
      – 256×240 optimized
      – 1920×1080 resolution
      I’m getting the same noise with two different SNESs, three different RGB cables, one with Luma Sync, two CSync RGB cables. I already tried three different power supplies for the SNES and another power supply for the OSSC. I tried all different combinations of power outlets in this room and tried to have the RGB cable as far away from the power supply and cable as possible. I put on ferrite chokes on the cables, which showed no noticeable difference. The noise was there before I modded the SNES with the RGB bypass, infact it was the reason to put in the bypass in the first place.
      I’ve ordered a 1chip recap kit from console5, but that’ll take a while to arrive and I’m not convinced it will help with the noise problem, since it also shows on my other SNES.
      I’m at the end of my rope. Does anyone have an idea how to approach fixing that issue?
      #37775
        What firmware on your OSSC?
        #37778
        nrq
          It’s on fw. 0.85a.
          #37782
          paulb_nl
            With all modes do you mean Line3x and Line4x also have this issue?
            Any of them an original Nintendo power supply?
            #37784
            nrq
              Line4x has the same issue, I haven’t tried the others yet.
              Yes, all three power supplies are original, genuine Nintendo power supplies. I have a bunch of SNESs around that came with different purchases.
              #37785
                Try a different display and if the problem persists, RMA the unit.
                #37799
                nrq
                  Sooooooo. About that. m(
                  Yepp. Different room, using my computer monitor everything is perfectly fine. No noise whatsoever. Super crisp picture. Couldn’t be happier. Captured everything here:
                  I assume there’s something generating that noise in the power line in the room with the TV. I’ll take everything off so that only the TV and the SNES with OSSC is connected and put everything back online piece by piece to figure out where the culprit is.
                  Thanks a lot for the help! As obvious as it is in hindsight, I wouldn’t have figured that out alone.
                  EDIT: turns out the culprit was the USB-C power supply for the Raspberry Pi 4 I got with the new TV for 4K videos. Problem solved.
                  #37827
                    Very frustrating. I had huge issues with powerline noise in the old house in UK and went through all kinds of things to prevent it. Eventually I had to use a pure sine wave UPS and a replacement linear PSU for sensitive consoles.
                    I’m surprised that turned out to be the culprit here though, as usually that’s wavy noise patterns, or at least it was in my experience.
                    #37917
                    RTStu
                      Glad you found a solution. I came into this thread expecting a little action on pixel edge boundaries and was shocked by the amount of random crawl.
                      #63219
                      Garry Crighton
                        mine has slight waves if im up close on certain games too i think its probably my retrotink scart to comp ps its just piggy backing off my lcd usb port funny i couldnt get the borti board to work on my snes jr but used a retrofixes board like 3 times in a row first try. not sure tf is up with borti rgb snes board
