Recommendations for a decent ~22-28" monitor with good OSSC Compatibility
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Recommendations for a decent ~22-28" monitor with good OSSC Compatibility
  • #23696
    Poeskas
      Hi all. I’m a long time reader but this is the first time I’ve posted here, now that I’ve got my new OSSC. I am really enjoying it, but it only works on one of my displays that is in a sub optimal location for it. So instead of moving that display, I’d like to find a new one, and I’m wondering if anybody could make a good recommendation for a quality LCD monitor I could use with my OSSC (primarily for NTSC SNES games) at Line5x. I know there is a thread that aggregates reports on monitor compatibility, but in this thread I would like to hear your personal opinions. Any advice would be greatly appreciated!
      #23703
        If you haven’t already, you may want to consider getting a dejitter mod installed in your SNES; that should improve display compatibility to a degree by eliminating the console’s janky sync signals, and then you only need to worry about a finding a monitor that can handle its 60.08Hz framerate instead of one that handles both its framerate and janky sync.
