I’ve been using my OSSC for the better part of 3+ months and for the most part I’ve been really enjoying it. Component output on the Wii is basically perfect. VGA with a Dreamcast is great, though there are issues with the length of the image that need to be manually adjusted which will then impact other outputs such as the Wii.
However, I just recently tried using the OSSC’s RGB output with a modified N64. The image is off, with a great number of random red dots. It sounds similar to an issue Adam Koralik described in a Youtube review.
I’m wondering if anyone can offer input on this issue?
