Resolution changes on Trinitron
NewHome Forums Koryuu Transcoder Resolution changes on Trinitron
  • #59650
    SargeSmash
      Just got my Koryuu in and it’s working great. I had a question regarding resolution switching – I have it hooked into a Trinitron (only component + composite), and when resolution changes happen (like in Resident Evil 2 for N64 or the menu screens in Chrono Cross), the image loses sync ever so slightly. Basically the image kinda jitters a little bit for a second before the TV locks in again. I assume that’s expected behavior? Seems to be the same on a Panasonic set as well. It’s not a huge deal, but curious just the same.
      • This topic was modified 1 year, 10 months ago by SargeSmash.
      #59666
        Is this a CRT we’re talking about? If so I’d expect only a slight “jitter” as you say, at the very most. Koryuu like pretty much all modern devices is digital in nature and not simply an analogue to analogue conversion.
        #59669
        SargeSmash
          Yep, they’re both CRTs. I figured that was going on, that there’s at least a small processing delay in swapping resolutions. It really is a pretty small jitter overall before it locks back in, and way, way better than the delay I see with other devices when swapping from 240p to 480i. Thanks!
          Also, I love the way things look on this Trinitron through the Koryuu – it really does have some serious pop to the visuals!
