This last black friday I purchased a Retrotink 2x Pro to upgrade from my Retrotink 2x v3.1. To my surprise the pro is much noisier. There is very visible vertical rolling noise coming from the pro.
My TV under test has had all post processing disabled as much as possible and is running in game mode. To test I first attached my svideo cable directly to a framemeister and observed no noise. Next I attached to my older v3.1 retrotink 2x in passthrough, then to a dac, finally back to the framemeister and observed almost imperceivable noise. If you’re sitting back a few feet you can’t tell. Next I attached the retrotink 2x v3.1 directly to the tv with a 2x scale and observed near imperceivable noise. Repeating the previous two experiments with the pro yielded noticable vertical rolling noise. The power supplies are the same in these tests between the retrotinks. I have tried alternate power sources with the same results. The hdmi cable from the pro has also been swapped and is better shielded than the non-pro.
I also tested connecting the retrotinks to an ossc and gbs8200 with the exact same results. There are no switches in this test setup.
Is this normal? Has anyone else compared using a n64 or Gamecube with svideo?
