RetroTink + OSSC not displaying VGA Input
NewHome Forums RetroTink Products RetroTink + OSSC not displaying VGA Input
  • #48933
    World Star 9
      Hello, I recently purchased a RetroTink 2x Mini to use with my NTSC N64 to improve the quality from Composite to S-Video (The RetroTink 2x Mini comes with an S-Video Cable)
      However when hooking up the necessary components to set it up, I either get nothing, or get very infrequent spurts of video that last for 1-3 seconds.
      The Tech Components are as follows:
      An NTSC Unmodified N64
      An N64 S-Video Cable included with the RetroTink 2x Mini
      A RetroTink 2x Mini (With V1.2 Firmware to allow passthrough)
      An HDMI to VGA Adapter by TENDAK: (https://www.amazon.com/Tendak-Converter-Adapter-portable-Connector/dp/B01B7CEOVK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1534103429&sr=1-1&keywords=tendak+vga&dpID=41gEIj1kRmL&preST=_SY300_QL70_&dpSrc=srch)
      The OSSC with the included PSU on V0.88 Audio
      This then leads to my Elgato 4K60 Pro which is connected to My Computer internally
      The RetroTink 2x Mini works as intended when plugged into the Card directly (No OSSC), and the OSSC detects SYNC from the RetroTink but doesn’t display a picture.
      I’m unsure of what I’m doing wrong
      Thank you for reading my post
      – World Star 9
      #48963
        Can you test the Tendak adapter with another source? Also can you use an external PSU with the Tendak?
        #48966
        World Star 9
          Sure, I can confirm that the adapter works with my Nintendo Switch plugged into my VGA Monitor. However my adapter doesn’t have a PSU of it’s own. So I may need to purchase the one provided by VGP. Thanks for the reply
          #49180
            Does N64->RetroTINK Mini (linedouble mode)->HDMI to VGA->TV work correctly?
