Hi!
I installed the RGB bypass amp 4.1 into my Super Famicom Jr., but I’m not getting any signal into my ODV-GBS-C. I’m using a PackAPunch CSYNC 470 Ohm SCART cable. I first tried it with just the J2 jumper closed and then with J3 closed too. Then finally with both open. The ODV-GBS-C isn’t recognizing any signal no matter how I wire it. The cable works with my other Super Famicom and I’m pretty sure it has CSYNC coming in from multi AV out pin 3. The scaler works with all my other consoles. I also know for a fact the console powers on and is running the game.
Can anyone point out where I might have made a mistake? Is there anything I could do to pinpoint the problem? If nothing else works, is it possible to wire R, G, B and CS into the S-RGB chip instead of the S-CPUN chip? I know the S-RGB is where you’d normally tap for S-Video, not RGB SCART, but I saw one guide for an older amp board that had CSYNC wired from the S-RGB chip straight to multi AV pin 3. Could I try that?
