RGB NTSC Video Passthrough
  • #56436
    Nickandre
      Hey! I have a vintage Sony Saticon camcorder with RGB output over BNC + TTL Sync + Composite video outputs from the camera control unit. I’m hoping to find a solution to convert the RGB to HDMI. I was successfully able to get it converted to VGA using a sync separator and the levels look decent albeit not quite to spec (I was able to tweak some pots inside the camera control unit to boost levels a bit). I‘ve picked up an OSSC to see if it will work in this application.
      Upon seeing the availability of TTL Sync on AV3 I tried that but the device syncs at “262p” or sometimes “263p”. I noticed the mention of an interlacing hack for AV3 to work around the TVP7002 issue; where are the details for that?
      I also have a SCART breakout cable but it seems to be the wrong pinout on sync; is it easier to just use the SCART to parse the sync out of the composite video if that’s an option as opposed to trying to finagle interlaced TTL sync?
      #56438
      Nickandre
        Ok fixed my SCART cable and the input works fine. The result from AV3 with TTL sync was epilepsy inducing.
