scanlines grid
  • #63337
    Daneeall
      I wonder if there is a way to set scanlines filter as grid for generic modes, just like GBA Consolizer does?
      I tried custom scanline setting with no avail.
      Here’s some pictures of the subject:
      #63421
        It should be possible. Have you set custom H & V intervals and strengths under custom scanlines?
        #63434
        Daneeall
          It doesn’t seem to be possible for generic mode. Or I don’t see a way to set correct vertical interval. Changing values for sub-columns 3,4,5,6 doesn’t do anything.
          Setting “Sl. alternating” and “Sl. alt interval” doesn’t affect vertical lines either.
          Actually that nice grid can be seen but only in “optimized” modes and not in generic =(
          #63437
            Are you on v1.11 firmware? With the following settings you should get a grid:
            Scanlines: On
            Sl. type: Custom
            Sub-line 1 str: target str
            Sub-column 1 str: target str
            H interval: Auto or preferred
            V interval: Auto or preferred
            #63440
            Daneeall
              Oops, I’m on 0.88 Looks like I have to mod my unit. Thank you.
              Some offtop: if I do update now, I will loose all the profiles, right?
              • This reply was modified 9 months, 4 weeks ago by Daneeall.
              #63442
                They are not compatible with 1.11 so they won’t get loaded on it. Any time you save a profile on v1.11, it overwrites the slot in question.
                #63445
                Daneeall
                  Thank you. What’s the best way to preserve em that it can be used in new firmware? I have about a dozen profiles.
                  #63545
                    You should be able to convert profiles between different versions (with some limitations) using this web tool: http://pbnl.byethost7.com/ossc/profiles/?i=1
                    #63553
                    Daneeall
                      So I should update to latest firmware that doesn’t require hardmod, then backup profiles and convert, then do the hardmod and update to 1.11 and restore converted profiles, right?
