Screen rotate option – Is it possible?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Feature Requests Screen rotate option – Is it possible?
  • #10899
    Galdelico
      Hi marqs,
      I’ve got a question that may interest many retrogamers/vertical shmups aficionados.
      Most modern PC monitors (I use an LG27MU67, with the OSSC) that support the pivot function, can only be rotated 90° clockwise, which means that all the vertical shooters that don’t provide any screen configuration, get displayed upside-down. I’m aware third party VESA mounts exist, but for convenience’s sake, do you think it’s possible to add a ‘rotate 180°’ option to the geometry settings on the OSSC?
      Thanks in advance! ^_-
      #10907
      AetherSmith
        I believe this is a duplicate of https://videogameperfection.com/forums/topic/rotate-screen-180-degrees/.
        Unfortunately, rotation is impossible without a full framebuffer (and would unavoidably add a full frame of lag).
        #10909
        Galdelico
          Oh yeah, same question basically. Sorry I should’ve read more carefully. ^^;
          Thanks for clarifying!
