Sega Genesis model 1 issue!!! please help!
NewHome Forums General gaming Sega Genesis model 1 issue!!! please help!
  • #17700
    MCLiLBas
      Hello,
      Can anyone help me please? I searched about this issue but couldn’t find any answers!
      Please check the right bottom corner of the image, there is a line that moves when i play any games, it reacts to the sound, it moves with sound!
      View post on imgur.com
      How can I get rid of it please?
      BTW, I have two Sega Genesis model 1, and they are both like that!
      Thank you in advance!
      #17702
        Totally normal, the Megadrive always displays these junk pixels in that area. You never noticed on your old CRT because typically CRTs overscan that region of the picture out.
        #17703
        MCLiLBas
          Thank you so much for your reply!
          At least it isn’t an issue with my consoles!
          Any recommendation to fix it? I have OSSC 1.6
          Appreciate it!!!
          #17729
            If you don’t like it use the mask feature in the OSSCs post-processing menu.
