Sega Mega Drive / Genesis versions
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Sega Mega Drive / Genesis versions
  • #19937
    Lostdotfish
      Just after a little guidance on getting the best model to use with the OSSC. In the wiki it states it is best to use a real NTSC US console rather than a modded Pal console due to timing differences in the hardware.
      Well, US Genesis consoles aren’t so easy to find in the UK right now. Just wondering if Japanese imports modded to English language would work as well with the OSSC as a US console?
      #19938
      Deleted User
        Japanese Imports are real NTSC consoles, so yes, they will have the correct refresh rate. Just cut the trace at JP2 and you will have an English NTSC Console. Also the cartridge slot is different, so you have to grind the edges.
        But please look on us ebay before doing that. You can find really cheap Genesis consoles and many of them ship to Europe, thanks to the ebay global shipping program.
