Sega Mega drive Master System Converter
NewHome Forums General gaming Sega Mega drive Master System Converter
  • #37152
    Hitch
      Hello everyone, please if you can help me I’d really appreciate it. I bought a 2nd hand Megadrive MK1 1600-05 which works fine I then bought a master system converter but it can’t get the thing to work. It seems like the game is actually working but the picture isn’t. They look like these pictures. I have taken it apart and cleaned it with IPA but no success. Thanks for any help.
      https://www.dropbox.com/s/57gwulr8rj9ev2z/IMG_20200404_163812.jpg
      https://www.dropbox.com/s/es77h4jhc56r3cr/IMG_20200404_164051.jpg
      #37377
        Press the reset switch on the Megadrive does that do anything to help?
        #37380
        Hitch
          Thanks for the reply. Turns out that the scart I was using in its own didn’t like the TV. I bought a retrotink scart from yourself which came a week ago connected it all up and boom the converter now works fine.
          #37396
            Hmm, I find that hard to believe given the screenshots you sent but, long as it is working for you now I guess it doesn’t matter 🙂
