Silent Hill 2 White lines on screen
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Silent Hill 2 White lines on screen
  • #40665
    Petter Olsson
      Im using an OSSC and played Silent Hill 2 on an OLED tv with no issues. However when I switched to my PC monitor (PG279Q) a white line started to appear on top across the whole screen. Like this. Hopefully it shows it clearly enough.
      https://ibb.co/gmTgntF
      https://ibb.co/Sx3Fnsr
      The OSSC is set to 480i with 2x bob de-interlacing (it shakes like crazy on passthrough mode) and im using a SCART packapunch cable from Retrogamingcables.com.
      Does it have anything to do with the way monitors de-interlace? I dont know, i need help though =)
      #40712
        Which firmware are you on?
        #40723
          Is the white line always in the same place, does it stay permanently or come and go?
