Sleep mode needs power reset
  • #62310
    Opualuan
      I’ve had issues with ossc pro going to sleep and not waking up. Recently I changed the av3 input, display/osd/oled went off, no leds. Waking with remote or power button on the unit doesn’t work, only unplugging power for a time. I was using old fw- upgraded to .75 and it’s happened again. Is this a know issue?
      #62323
        Sounds like a hardware defect since there is no such sleep mode. Did that only start occurring after some usage period? You can try if resetting settings to defaults helps, otherwise RMAing the unit may be the only option is the problem persists.
        #62468
        Opualuan
          I’ve seen it since day 1. Reset/fw didn’t help. Going to investigate rma.
          #62469
          Opualuan
