Snes ghosting
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Snes ghosting
- This topic has 23 replies, 10 voices, and was last updated November 1, 2017 at 2:18 AM by
eric90000.
December 6, 2016 at 1:00 PM #10139
I can see some ghosting on my TV while using SNES. For example, if Mario jumps and background is white, I can see a ghost Mario at right. The lives counter causes a shadow that goes all way down, etc.
Testing the same Snes with Framemeister causes no ghosting.
Snes: PAL one chip, with SuperCIC mod. Playing a PAL game in 50 Hz.
OSSC: connected to Scart input, selected input 1. Default settings, 576p output.
Cable: rgb luma sync from retrogamingcables.
Framemeister: picture mode, tested in 1080p and 576p 50 hz. Euro Scart adapter with csync circuit.
Tv : Sony kdl42w750b. Tested on the same hdmi input, all processing disabled.December 7, 2016 at 12:24 PM #10162It would probably help if you posted a picture. It could be the rgb cable thats causing it. Do you have issues with other consoles?
December 7, 2016 at 12:39 PM #10163The problem with the pictures I’ve taken is that the effect is hard to notice, but I will post them later.
I used the same cable to test with the Framemeister. Previously I was using the old SNES PAL RGB cable that retrogamingcables provided that had not luma sync, and I had image noise also only with OSSC. I guess that the Framemeister is somewhat filtering all those image issues.
I have also a SNES RGB NTSC with csync cable from retrogamingcables that I may test in some days.
December 7, 2016 at 12:50 PM #10164Its probably the sync stripper inside the Framemeisters scart adapter thats filtering the issues. Did you also see the shadowing with the rgb cable without luma sync?
December 7, 2016 at 11:11 PM #10172It’d help if you can try another console on the same input to isolate the issue to snes, cable or ossc. Framemeister probably has a bit stronger LPF than OSSC in sdtv mode, but you shouldn’t see noise/ghosting with a quality cable and well-conditioned console (e.g. no leaky caps).
December 8, 2016 at 8:05 PM #10194Actually ghosting is supposedly quite common on the 1-chip RGB modded consoles. I’ve been looking at ways to eliminate or minimise it with modding.
December 8, 2016 at 9:52 PM #10207I’m not sure if you will be able to see the “shadow Mario” at right in the first image since it’s hard to notice in the picture I took. But while playing it is very distracting 🙂
OSSC:
Framemeister:
This one is not RGB modded since it’s a PAL one chip (not Mini, I can’t tell which board version right now).
I’m waiting to receive my SNES mini with the NTSC cable from the mail so then I will be able to check with that console and cable too. Next week I will also check the old RGB cable without luma sync.
December 9, 2016 at 3:26 PM #10227Your problem is the 1Chip-SNES and not the OSSC! You will observe the same problem with your SNES Mini…
http://shmups.system11.org/viewtopic.php?p=1226995#p1226995
Just a guess.. it might be not noticeable at the Framemeister because the Framemeister saturates the input signal at standardized Upp levels… If this is the case the problem is not noticeable… just a guess…
December 20, 2016 at 9:44 PM #10485Ok thank you, I’ve also tested that Snes with a BVM and I can see the ghosting.
So by the post you linked in shmups forums I guess the only way to fix any of my SNES (pal one chip or mini) for the OSSC or the BVM is a nearly impossible mod… Is anybody making that 1-resistor mod?
I will keep using the Framemeister since the ghosting is not noticeable with it.
And I thought that it could be easy to find a good SNES…
October 24, 2017 at 10:36 PM #16377Hey, I’m also getting pretty bad ghosting on my SNES mini w/ Voultars RGB mod. Has there been any progress on solving this and getting rid of the ghosting?
October 25, 2017 at 8:43 AM #16381Yes, this is supposed to be a problem of the past when the new mod is installed with the brightness fix.
October 25, 2017 at 9:10 AM #16385What if we already have the RGB mod installed? In my case a custom board with SuperCIC and Borti RGB mods. Is it worth to apply for example only the ghosting fix? (providing I send the snes to you for example).
October 25, 2017 at 1:07 PM #16388We could probably do that assuming the custom mod was installed to a good standard.
October 25, 2017 at 9:05 PM #16400I don’t believe this is a brightness issue. It seems to be a problem with certain 1-CHIP SNES’. Voultars board fully attenuates the signals and outputs perfect RGB, so I know it’s not an issue with the RGB bypass. I’m noticing a lot of the same ghosting effects as others with 1-CHIP consoles, and apparently it’s largely dependent on your display as to whether or not it’s obvious.
Borti has a supposed fix for this by lifting pin 155 of the CPU and connecting a 20ohm resistor in series to vcc. The resistors on the RGB board would then need to be removed. This just seems a little bit extreme, and is quite risky given that the pins are tiny and access is limited.
I’m really surprised there aren’t more people with this issue…now that I’ve noticed it it’s really annoying me. Voultar has said he’s working on a potential alternative fix for the ghosting on 1-CHIP consoles. If I dig up any more information I’ll report back here.
October 25, 2017 at 9:39 PM #16405We use Borti’s fix in our workshop and we’ve had great results with it.
