The Bridge has been seen on a few consoles, its a factory manufacturing issue however not a big deal as both those pins are ground anyway.
Advise removal before fitting the bypass board.
Before fitting the board to a junior you need clop the pins on 3 capacitors, the 2 in your picture and one further right.
Also ensure you insulate the underside of the board with tape.
Ensure you have fitted 1k2 resistors to the rgb pads as required and you can replace c11 with a 220nF capacitor to reducer ghosting.
I would reflow your rgb connections on the pcb socket header, remove existing solder first, you don’t need much but you do need to keep each pin heated for a good 6 or seven seconds to ensure a smooth even solder joint on all the parts.
Csync should be taken from pin 18 of the video encoder.
Finally ensure you have correctly set the jumpers for attenuation or csync buffering.
