It seems the info about the SNES on the wiki contains an error, suggesting to adjust coasting rather than loop gain (I had a feeling there was something off.)
I suspect there to be this mistake too.
The text quoted below describes exactly what happens when I increase Loop Gain. Post-Coast set to 1 would be a decrease from its default value on the OSSC Pro (4). A Loop Gain of higher than 1 indeed breaks compatibility with my capture card, while Post-Coast even at 4 does not. (And Post-Coast is supposed to be decreased to zero in the OSSC instructions.)
PLL bandwidth can be increased via “AV1-3 sync opt -> H-PLL Post-Coast“. Usually value 1 is enough to clear the jitter while preserving display compatibility. With higher values framelock may need to be disabled to ensure display can sync with the signal.
This reply was modified 5 months, 2 weeks ago by
lyrical.
