I’ve noticed the last while when playing Super Mario Bros. 2 that if I’m near a bright area like the white clouds behind me or the sky, I can see a ghosting or trailing effect of stuff to the right. For example, a beanstalk is the most noticeable one and you can see that the trails are also animated. It’s a one chip PAL model, would this be the unit itself or the cable? I’m using a GameCube cable and I turn ADC Gain down to 5 to eliminate the bright colours clipping, but if I had the other cable with the in-line resistors, I feel like the issue would be still present.
It’s not entirely bothersome, but it’s just the fact that it’s there and I wonder if it’s normal or not. I’ll try to get a picture if I can or else just grab a 2x screenshot with my capture card and see if it turns out on it.
