SNES sync issues after mod
Viewing 15 posts - 1 through 15 (of 46 total)
  • #14513
    blackice85
      Hi, I’m having some sync issues with my SNES after getting it back from Voultar for a newer RGB mod. Are there any specific settings that might help here? The resolution jumps from 261 to 262p rapidly, along with the frequency 60.05Hz to 6.24Hz. Before sending it out I never had to mess with anything, hopefully there’s a fix for this.
      #14519
        Are you on the latest OSSC firmware ? (0.78)
        #14520
        blackice85
          Yeah. I was on 0.77 (and earlier) where it worked previously, and upgraded to 0.78 while it was out for modding. First thing I did after seeing it not work was to try downgrading back to 0.77. For the sake of troubleshooting I can change it back to 0.78 though.
          #14522
            Any details about original and new mod?
            #14527
            blackice85
              Original mod was a simple 3-wire style DIY that used it’s own amp, the new one is the THS7374 amp installed by Voultar.
              http://voultar.com/index.php?route=product/category&path=60_62
              Seems like it syncs to the display less often when the AV receiver is in the mix, but previously it didn’t care.
              #14528
              blackice85
                I think I found what it was, it was line doubling that it doesn’t like now. It’ll still sync up most of the time with linex3 and x4, but not linex2. I knew the higher linex modes aren’t compatible with all displays, but I didn’t think to check that the lowest was no longer compatible.
                Maybe the new refresh rate combined with the odd resolution pushed it out of the acceptable range?
                #14540
                paulb_nl
                  Are you using a CSYNC cable and is the new mod set to 75Ohm CSYNC or TTL CSYNC?
                  #14542
                  blackice85
                    Yeah it’s a CSYNC cable from retrogamingcables.co.uk
                    As for the mod, I don’t know offhand. It looks like it can be set to either by setting a jumper, so I’ll have to open it up later to see.
                    Presently, it’ll sync up 99% of the time if I turn it on, and then reset the SNES after a few seconds. Seems like it settles on a stable frequency somehow. Not sure why resetting it works, but that seems to fix it, just powering it on is hit or miss.
                    #14543
                    eric90000
                      I’m fairly certain Voultar sets his boards by default to attenuated 75Ω CSync.
                      I’d be willing to bet that the cable you’re using, also has attenuation built in (resistor on sync line), in order to bring the SNES TTL CSync output level down to 75Ω terminations.
                      So if these two are the case, you might be attenuating the sync signal twice, which could explain your issues? Voultar told me that if you’re using his board with 75Ω jumper on, then make sure there’s no resistor on the sync line in the SCART head on the cable.
                      Hope this helps
                      #14546
                      blackice85
                        Ah, so it could be as simple as just switching the jumper then? Seems like an easy thing to test for, I’ll do that later then.
                        #14547
                        eric90000
                          It’s certainly worth a try. First thing to do is to pop open the SCART head and check if there is a resistor on the Csync line. If there is, then jump the TTL on Voultars board. Just be careful and make sure you don’t end up sending TTL level straight to your OSSC. This can put added strain on it and reduce it’s life span.
                          #14549
                          paulb_nl
                            @eric90000 Thats what I was also thinking. Voultar setting his boards by default to 75 Ohm CSYNC doesn’t make any sense. All CSYNC SNES cables sold should have the 330 Ohm resistor in them and its dangerous to use a cable without components on the sync line if you connect it to an unmodded SNES by mistake.
                            #14551
                            eric90000
                              Yep that’s true. I wonder though, does Voultars TTL sync output level match that of a stock SNES? Do you reckon that:
                              Voultar TTL setting > SCART cable with 330-450 ohm resistor on the csync line
                              is the same as:
                              Voultar 75Ω setting > SCART cable with NO resistor on the sync line
                              I’d love to know if both output levels are within acceptable and safe range?
                              If anyone hasn’t seen it, Bob from RetroRGB has a pretty helpful page on his site with Csync info, as well as a pretty helpful video: http://www.retrorgb.com/csync.html
                              #14552
                              blackice85
                                Yep looks like I got a resistor in my cable, so I’ll open up the console next and see what it’s set to.
                                Edit: Looks like the TTL jumper is shorted, so that’s right as far as I understand it.
                                #14555
                                blackice85
                                  I’m including a video link of what it does when it decides to act up, in case that’s helpful.
                                  https://drive.google.com/open?id=0BzqLju9MJloEczRYNTN5Qm10QUE
