Softening/Blur filter
  • #40169
    Achelon
      I suspect I’m alone here but I would love to see some sort of blurring/softening filter (with configurable on/off and strength %) – not asking for any fancy upscaling effect, just a softening/blurring ability. I don’t know if this request is the same thing as the request for “smoothing filters” which has already been made in this subforum but if it isn’t I’d love to see it.
      Achelon
      #40189
        I’d love this as well. A 3-tap or 5-tap horizontal softening filter and 2-tap vertical softening filter would be welcome, if possible.
        #41075
        AJBats
          Came to request this feature, and found this thread!
          There’s something similar on the Koryuu, though I know its experimental, it’s the right idea of what I’d like to see. Definitely would love to see this feature with multiple steps of blur strength. I sometimes play with composite piped in through the Koryuu just to get this effect with the natural blurring of composite signals. I find composite + Koryuu + OSSC 5x with thin scanlines is pretty faithful to the original experience on a CRT. However, it would be better to recreate this with a cleaner signal of component/RGB.
