I have just installed the RGB bypass board, and unfortunately I have some trouble.
The image start flickering slowly after few seconds, more less sync problem ??
]My setup is :
BVM20F1E
Retrogamingcable RGB Genesis Packpunch
Core Grafx (with 0 mod)
Before the mod, I was using the same setup without any trouble.
I try my Core Grafx alone without SSDS3 using composite video cable, and it works fine.
I check many time every connections and everythings seems good.
Some pictures :
http://tomtom2k5.free.fr/ssds3/IMG_3103.jpg
http://tomtom2k5.free.fr/ssds3/IMG_3104.jpg
If someone have some ideas.
Thanks.
