Static blue image with some vertical lines on N64 Advanced VGA output
NewHome Forums Repairs and Upgrades Static blue image with some vertical lines on N64 Advanced VGA output
  • #45929
    milosonator
      I’m having an issue with the video output on my N64 Advanced. It seems to output a bad image, even though it looks like a valid VGA output, and the screen syncs correctly. It’s a mostly blue image with some vertical lines it seems:
      Bad image
      I’ve installed the N64 using the flex cable on a PAL N64, no jumpers are set, I’m using normal VGA output (h/v sync lines, RGB and GND). The composite output of the N64 is good. It’s hooked up to the same screen and switching between inputs shows the good output, but on the N64 Advanced, it’s wrong.
      Any help with debugging this issue would be greatly appreciated. Seems perhaps there is some bad data coming from the N64?
      I’ve checked the connections, but not sure if there is something I’m missing. I’ve got the flex connected, and the 5V line to the N64 5V regulator. Other than that I have my VGA outputs hooked up to the screen. 5V, 3.3V and GND all verified. Not sure how to verify the other lines, since they seem to pass through some components on the flex.
      Album with images: Album
      #45951
      milosonator
        Update: depending on the scene shown (running Mario 64, it plays through a couple of demo scenes) the image in the certer vertical ‘bar’ shows a variety of moving/changing, vertical lines. So some data is making it through.
        #46016
          No jumpers set.. hmm, don’t you need to set jumpers for line double mode if you’re using a VGA monitor?
          #46168
          milosonator
            The manual says the following:
            > J4.1: – opened: linedoubling enabled
            Therefore, I have left the jumper open.
            #47411
              Did you ever figure this one out?
              #47425
              milosonator
                Unfortunately, I have not figured this out… So if you have any ideas on what this could be or approached how to debug, I’m all ears.
                #47461
                  Did you get the board from us? Have you tried connecting to a different display?
                  #47502
                  milosonator
                    Yes I did acquire the board from VGP. I will try another display as a next step of trying to resolve this issue.
                    #47701
                    milosonator
                      I’ve tried again with a different display and with a different Nintendo and the N64A now works correctly.
                      I’ve then tried with a similar screen (but different unit), that worked too. So either the problem is with the original screen, the original Nintendo, or my wiring 😎.
                      Biggest difference is that I tried now with an NTSC Nintendo 64 rather than a PAL one. So one plausible explanation is that the original display didn’t support whatever display was being output.
                      Either way the N64A is working, and especially on 240p the image is crispy.
